ser
1
Would anyone have any generic multidispense liquid classes for filtered or non-filtered tips?
More specifically the surface part volume for water for 50ul filtered tips?
Would using the surface empty tip correction curve be a smart place to start?
Thanks
See this link for an example surface part liquid class for 50uL tips.
Use 2mm submerge depth on the aspirate and dispense. No pre-mixing. Incorporate 1 pre- and 1 post-aliquot of the same volume.
ser
3
thank you! I will try this out
ikari
4
For this liquid class, how low can this dispense volume go?
