the cell will run forever and not return anything.
I’ve traced it down to the websocket send_command() function, specifically the section
if wait_for_response:
while True:
if len(self.received) > 0:
message = self.received.pop()
if "id" in message and message["id"] == id_:
break
time.sleep(0.1)
What seems to be happening is that self.received is filling up with lots of dictionary messages (either {‘event’: ‘ping’} or {‘event’: ‘pong’, ‘success’:True} but since none of those have a ‘id’ key, we get stuck in that loop forever.
Is this intended? Any ideas about what I’m doing wrong? Thanks
Could you check the JS console of your browser for errors? Sometimes, when a fatal error occurs, the client library is unable to send a response to the server, causing the server to wait indefinitely. (Actually I think I’ll just add a timeout parameter.)
Since Opentrons have the option of mounting different pipetting heads with a different number of channels, there should really be an option to configure that in the simulator (as I wrote in the comment in the linked code), which does not exist yet. If you have ideas on how to best implement this, I’m happy to hear them!
More immediate solutions:
You could change the code to load more channels for the OT, analogous to STAR. Reload the page and you should be good.
Depending on your setup, you may also want to perform a single operation at a time (await lh.pick_up_tips(tip_0["A1"]))
switch (event) {
case "resource_assigned":
resource = loadResource(data.resource);
resource.draw(resourceLayer);
print('Is this thing on? prints from backends/simulation/simulator/sim.js')
if (data.resource.name === "deck") {
// infer the system from the deck.
if (data.resource.type === "OTDeck") {
system = SYSTEM_OPENTRONS;
// Just one channel for Opentrons right now. Should create a UI to select the config.
for (let i = 0; i < 8; i++) {
mainHead.push(new PipettingChannel(`Channel: ${i + 1}`));
} else if (data.resource.type === "HamiltonDeck") {
system = SYSTEM_HAMILTON;
break;
I adjusted the Opentrons line to match the same strategy for loading multiple channels as with Hamilton decks (is this what you meant?) but it doesn’t seem to have changed anything. In fact, the print statement I put in doesn’t even seem to be triggering, so I’m not sure this code in sim.js is getting run at any point when I run through using-the-simulator.ipynb? (when i change other files it changes the result as expected)
The simulator actually determines the liquid handler that is running depending on the deck. That means if you change the STARLet deck to OT, the simulator will run with a slightly different configuration.
print in Python would actually be console.log in JS. Further, I think you’re missing a closing bracket for the for loop. Given that that did not give a syntax error, could you force reload the page? (Sometimes the browser will cache JS files.)
Thanks for the help! I think I found something that might have been causing the issue. I looked into the JS event that’s triggering for resource_assigned and for me the resource object named ‘deck’ has type ‘HamiltonSTARDeck’, where handleEvent is only looking for either ‘OTDeck’ or ‘HamiltonDeck’. I edited the javascript to look for a ‘HamiltonSTARDeck’ and everything seems to be working for me now. Appreciate the guidance!
