NTR added dynamically
Can my VisualNTR/nested-tip library recognize the dynamically instantiated NTR structure, display it correctly, initialize the count, maintain the stack state and continue giving me the same operator visualization?”
Hi @Bex,
The Visual NTR library is many years old now and is still routinely used today. Stacks of NTRs can be 4 tall and other than the GUI asking you to make sure you remove empty wafers at the start of a run it will remember the count and orientation of remaining tips from one run to the next when applied to your methods and used correctly. Just like the standard tip counting library and now the ATML, the available and remaining tips are stored outside of the VENUS method so that it can be referenced each time it is instantiated within a given run.
Matt
