Hello everyone, I just wanted to share a skeleton/template .py file that I made here for quick unit tests etc in case it’s helpful. It’s been really convenient as opposed to building a protocol file from scratch every time. And it’s also a good starting point to hand to a LLM for vibe coding a protocol. Maybe also helpful to see the overall structure of an Opentrons .py if you’re starting out.
Feedback also welcome!
from opentrons import protocol_api, types
from opentrons.protocol_api import ALL, SINGLE, PARTIAL_COLUMN
import math
import csv
import datetime
# Metadata
metadata = {
'protocolName': 'Template OT Flex Protocol',
'author': 'YN',
'description': 'Template OT Flex Protocol',
'source': 'YN'
# requirements
requirements = {"robotType": "Flex", "apiLevel": "2.27"}
# Global Offsets
Y_OFFSET_96_WELL = types.Point(y=-2.5)
XY_OFFSET_96_D_WELL = types.Point(x=1, y=-1)
# --------------- Opentrons Parameters --------------
def add_parameters(parameters: protocol_api.Parameters):
Adds user-configurable parameters to the protocol.
# --------------- /Opentrons Parameters --------------
# ----------- Helper Functions -----------
# ----------- /Helper Functions -----------
def run(protocol: protocol_api.ProtocolContext):
# --- Labware Setup ---
# Modules
heater_shaker = protocol.load_module(module_name="heaterShakerModuleV1", location="B3")
#heater_shaker_adapter = heater_shaker.load_adapter("opentrons_universal_flat_adapter", namespace="opentrons", version=1)
trash = protocol.load_waste_chute()
# Pipettes
#p1000_multi = protocol.load_instrument('flex_8channel_1000', 'right', tip_racks=tips1000_all)
# Labware
plate = protocol.load_labware(
"corning_96_wellplate_360ul_flat",
location="B1",
version=5,
lid="corning_96_wellplate_360ul_lid",
lid_namespace="opentrons",
lid_version=1,
# Wells
dpbs = plate.wells_by_name()['A1']
# Liquids
liquid_dpbs = protocol.define_liquid(
name="DPBS",
description="DPBS Wash Buffer",
display_color="#DAF5FF", # Light Blue
# Load Liquids
plate.load_liquid(
liquid=liquid_dpbs,
volume=1,
wells=[dpbs]
# --- Designated Tip Locations for Re-use ---
#dpbs_tip_location = tiprack_1000ul_1.wells_by_name()['A12']
# --- Setting Default Flow Rates ---
#default_aspirate_1000 = p1000_multi.flow_rate.aspirate
#default_dispense_1000 = p1000_multi.flow_rate.dispense
# --- /Labware Setup ---
###################### PROTOCOL START ######################
protocol.comment("--- Protocol Complete ---")
heater_shaker.close_labware_latch()
heater_shaker.deactivate_heater()
heater_shaker.deactivate_shaker()
