Does anyone know of a way of clearing the variable fields that the user initially enters at the start of the run on the Janus Application Assistant? When the run completes and one goes to start the next run, the variables last entered remain in the fields. We want to clear them to avoid any possibility of data from a prior run accidentally being left behind. I have located some .xml files that appear to store the values, but it appears to write the file as an output yet not use it as an input as to what it displays in these fields. Closing and restarting the software will clear the fields but I am looking for a means of clearing the fields after a run without having to restart the software.
Mike Mueller
