Read properties from .ctr file
im wondering if there is a way to read from the container properties loaded on a rack.
Im loading and adding containers onto a 32pos carrier during runtime via the DevAddContainerToRack.
On a later workflow step i would like to read manually set properties from the containers properties.
Only way i found was to read the properties of the corresponding .rck file (in my case the carrier) but the from the .ctr loaded on the .rck.
Any suggestions?
Hi @Manuel ,
Using LabwarePropertyQuery, you can parse the property from the container file using the following steps:
@BrandonBare_Hamilton Thank you. Thats what i was searching for. Works!
