I just started using pyhamilton just recently to create a script to support a method our Hamilton Star. The star we have has 4 - 5mL channels with 8-1mL Channels. Would it be possible to add the 5 mL channels to the command options?
Yes its possible with an extension of the API, shouldnt be too hard. In short you have to add a new function to universal method STAR_OEM_noFan.med/hsl. This would basically mean following the instructions here:
https://forums.pylabrobot.org/t/getting-started-with-pyhamilton/28/4?u=stefan
However these instructions might be out of date or lack details. Ill send more clear instructions soon.
Awesome! I was able to add the 5 mL Channels command set list and run a test command. Works as expected!
Thanks Stefan!
Whoa sweet! Glad to hear it! Do you want to make a pull request to the master repo?
I would but I had to remove a few of the other commands including the Inheco and pH module as I was running into some errors.
Let me retry and get back to you.
Ok cool, I’m happy to help with any problems (I’ve seen it all before) and would be thrilled to assist with making a PR
