Hi everyone,
I am new to this forum but have 5+ years of experience with low-cost automation, love coding and have been wrangling my way through the Hamilton Universe for half a year. I am very excited about PyLabRobot’s flexibility and can’t wait to start proper programming for automation on high-end machines.
I ended up being stuck at the setup stage, and would like to ask whether someone has encountered this error and knows a way around it.
Background:
Liquid Handling System: Hamilton Microlab STARlet (8-channel, no iSWAP)
control: using a separate laptop for PyLabRobot (PLR) to avoid having to switch driver back and forth from VENUS to PLR
OS: tried out on both (1) Windows 10 (factory reset for this purpose), (2) MacOS Ventura (M1)
Python distribution: miniconda3
constructed virtual environment using conda, installed Python 3.10
after environment creation instantly installed pylabrobot from source using git (as described in the docs) but also tried out pip installations
The Problem
After running this minimal setup script in a Jupyter Notebook…
%load_ext autoreload
%autoreload 2
from pylabrobot.liquid_handling.backends import STAR
from pylabrobot.resources.hamilton import STARLetDeck
backend = STAR()
lh = LiquidHandler(backend=backend, deck=STARLetDeck())
await lh.setup()
…I encounder this complete error message (os.environ[‘PYUSB_DEBUG’] = ‘debug’ to give detailed information about what PyUSB is doing):
2023-12-22 09:32:33,913 INFO:usb.core:find(): using backend "usb.backend.libusb1"
2023-12-22 09:32:33,914 DEBUG:usb.backend.libusb1:_LibUSB.enumerate_devices()
2023-12-22 09:32:33,915 DEBUG:usb.backend.libusb1:_LibUSB.get_device_descriptor(<usb.backend.libusb1._Device object at 0x10ccc23b0>)
2023-12-22 09:32:33,915 DEBUG:usb.backend.libusb1:_LibUSB.get_device_descriptor(<usb.backend.libusb1._Device object at 0x10ccc24a0>)
2023-12-22 09:32:33,916 DEBUG:usb.backend.libusb1:_LibUSB.get_configuration_descriptor(<usb.backend.libusb1._Device object at 0x10ccc23b0>, 0)
2023-12-22 09:32:33,916 DEBUG:usb.backend.libusb1:_LibUSB.open_device(<usb.backend.libusb1._Device object at 0x10ccc23b0>)
2023-12-22 09:32:33,916 DEBUG:usb.backend.libusb1:_LibUSB.set_configuration(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 1)
2023-12-22 09:32:33,917 DEBUG:usb.backend.libusb1:_LibUSB.get_configuration_descriptor(<usb.backend.libusb1._Device object at 0x10ccc23b0>, 0)
2023-12-22 09:32:33,917 DEBUG:usb.backend.libusb1:_LibUSB.get_interface_descriptor(<usb.backend.libusb1._Device object at 0x10ccc23b0>, 0, 0, 0)
2023-12-22 09:32:33,918 DEBUG:usb.backend.libusb1:_LibUSB.get_endpoint_descriptor(<usb.backend.libusb1._Device object at 0x10ccc23b0>, 0, 0, 0, 0)
2023-12-22 09:32:33,918 DEBUG:usb.backend.libusb1:_LibUSB.get_interface_descriptor(<usb.backend.libusb1._Device object at 0x10ccc23b0>, 0, 0, 0)
2023-12-22 09:32:33,918 DEBUG:usb.backend.libusb1:_LibUSB.get_configuration_descriptor(<usb.backend.libusb1._Device object at 0x10ccc23b0>, 0)
2023-12-22 09:32:33,918 DEBUG:usb.backend.libusb1:_LibUSB.get_endpoint_descriptor(<usb.backend.libusb1._Device object at 0x10ccc23b0>, 1, 0, 0, 0)
2023-12-22 09:32:33,919 DEBUG:usb.backend.libusb1:_LibUSB.get_configuration_descriptor(<usb.backend.libusb1._Device object at 0x10ccc23b0>, 0)
2023-12-22 09:32:33,919 DEBUG:usb.backend.libusb1:_LibUSB.get_endpoint_descriptor(<usb.backend.libusb1._Device object at 0x10ccc23b0>, 0, 0, 0, 0)
2023-12-22 09:32:33,919 DEBUG:usb.backend.libusb1:_LibUSB.get_interface_descriptor(<usb.backend.libusb1._Device object at 0x10ccc23b0>, 0, 0, 0)
2023-12-22 09:32:33,920 DEBUG:usb.backend.libusb1:_LibUSB.get_configuration_descriptor(<usb.backend.libusb1._Device object at 0x10ccc23b0>, 0)
2023-12-22 09:32:33,920 DEBUG:usb.backend.libusb1:_LibUSB.get_endpoint_descriptor(<usb.backend.libusb1._Device object at 0x10ccc23b0>, 0, 0, 0, 0)
2023-12-22 09:32:33,920 DEBUG:usb.backend.libusb1:_LibUSB.get_interface_descriptor(<usb.backend.libusb1._Device object at 0x10ccc23b0>, 0, 0, 0)
2023-12-22 09:32:33,920 DEBUG:usb.backend.libusb1:_LibUSB.claim_interface(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 0)
2023-12-22 09:32:33,921 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
2023-12-22 09:32:37,155 DEBUG:usb.backend.libusb1:_LibUSB.get_configuration_descriptor(<usb.backend.libusb1._Device object at 0x10ccc23b0>, 0)
2023-12-22 09:32:37,157 DEBUG:usb.backend.libusb1:_LibUSB.get_interface_descriptor(<usb.backend.libusb1._Device object at 0x10ccc23b0>, 0, 0, 0)
2023-12-22 09:32:37,158 DEBUG:usb.backend.libusb1:_LibUSB.get_configuration_descriptor(<usb.backend.libusb1._Device object at 0x10ccc23b0>, 0)
2023-12-22 09:32:37,160 DEBUG:usb.backend.libusb1:_LibUSB.get_endpoint_descriptor(<usb.backend.libusb1._Device object at 0x10ccc23b0>, 0, 0, 0, 0)
2023-12-22 09:32:37,161 DEBUG:usb.backend.libusb1:_LibUSB.get_interface_descriptor(<usb.backend.libusb1._Device object at 0x10ccc23b0>, 0, 0, 0)
2023-12-22 09:32:37,162 DEBUG:usb.backend.libusb1:_LibUSB.get_configuration_descriptor(<usb.backend.libusb1._Device object at 0x10ccc23b0>, 0)
2023-12-22 09:32:37,163 DEBUG:usb.backend.libusb1:_LibUSB.get_endpoint_descriptor(<usb.backend.libusb1._Device object at 0x10ccc23b0>, 1, 0, 0, 0)
2023-12-22 09:32:37,164 DEBUG:usb.backend.libusb1:_LibUSB.get_interface_descriptor(<usb.backend.libusb1._Device object at 0x10ccc23b0>, 0, 0, 0)
2023-12-22 09:32:37,165 DEBUG:usb.backend.libusb1:_LibUSB.get_configuration_descriptor(<usb.backend.libusb1._Device object at 0x10ccc23b0>, 0)
2023-12-22 09:32:37,167 DEBUG:usb.backend.libusb1:_LibUSB.bulk_write(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 2, 0, array('B', [67, 48, 82, 84, 105, 100, 48, 48, 48, 49]), 30)
2023-12-22 09:32:37,169 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
2023-12-22 09:32:37,201 DEBUG:usb.backend.libusb1:_LibUSB.bulk_write(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 2, 0, array('B', [67, 48, 81, 77, 105, 100, 48, 48, 48, 50]), 30)
2023-12-22 09:32:37,203 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
2023-12-22 09:32:37,235 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
2023-12-22 09:32:37,237 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
2023-12-22 09:32:37,245 DEBUG:usb.backend.libusb1:_LibUSB.bulk_write(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 2, 0, array('B', [67, 48, 81, 87, 105, 100, 48, 48, 48, 51]), 30)
2023-12-22 09:32:37,247 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
2023-12-22 09:32:37,279 DEBUG:usb.backend.libusb1:_LibUSB.bulk_write(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 2, 0, array('B', [67, 48, 86, 73, 105, 100, 48, 48, 48, 52]), 30)
2023-12-22 09:32:37,282 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
2023-12-22 09:32:38,981 DEBUG:usb.backend.libusb1:_LibUSB.bulk_write(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 2, 0, array('B', [67, 48, 68, 73, 105, 100, 48, 48, 48, 53, 120, 112, 48, 56, 48, 48, 48, 38, 121, 112, 52, 48, 53, 48, 32, 51, 55, 56, 51, 32, 51, 53, 49, 54, 32, 51, 50, 52, 57, 32, 50, 57, 56, 50, 32, 50, 55, 49, 53, 32, 50, 52, 52, 56, 32, 50, 49, 56, 49, 116, 112, 50, 52, 53, 48, 116, 122, 49, 50, 50, 48, 116, 101, 51, 54, 48, 48, 116, 109, 49, 38, 116, 116, 48, 52, 116, 105, 48]), 30)
2023-12-22 09:32:38,984 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
2023-12-22 09:32:42,271 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
2023-12-22 09:32:45,586 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
2023-12-22 09:32:48,892 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
2023-12-22 09:32:52,202 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
2023-12-22 09:32:55,532 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
2023-12-22 09:32:58,901 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
2023-12-22 09:33:02,135 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
2023-12-22 09:33:05,145 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
2023-12-22 09:33:06,088 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
2023-12-22 09:33:06,091 DEBUG:usb.backend.libusb1:_LibUSB.bulk_write(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 2, 0, array('B', [82, 48, 81, 87, 105, 100, 48, 48, 48, 54]), 30)
2023-12-22 09:33:06,093 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
2023-12-22 09:33:08,090 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
2023-12-22 09:33:11,466 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
2023-12-22 09:33:14,778 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
2023-12-22 09:33:18,087 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
2023-12-22 09:33:21,420 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
2023-12-22 09:33:24,708 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
2023-12-22 09:33:28,041 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
2023-12-22 09:33:31,408 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
2023-12-22 09:33:34,712 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
2023-12-22 09:33:38,022 DEBUG:usb.backend.libusb1:_LibUSB.bulk_read(<usb.backend.libusb1._DeviceHandle object at 0x103ec6500>, 129, 0, array('B', [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]), 3000)
TimeoutError Traceback (most recent call last)
Cell In[3], line 1
----> 1 await lh.setup()
File ~/pylabrobot/pylabrobot/liquid_handling/liquid_handler.py:91, in LiquidHandler.setup(self)
88 if self.setup_finished:
89 raise RuntimeError("The setup has already finished. See `LiquidHandler.stop`.")
---> 91 await super().setup()
93 self.head = {c: TipTracker(thing=f"Channel {c}") for c in range(self.backend.num_channels)}
95 self.resource_assigned_callback(self.deck)
File ~/pylabrobot/pylabrobot/machine.py:49, in MachineFrontend.setup(self)
48 async def setup(self):
---> 49 await self.backend.setup()
50 self._setup_finished = True
File ~/pylabrobot/pylabrobot/liquid_handling/backends/hamilton/STAR.py:1254, in STAR.setup(self)
1241 y_positions = [4050 - i * dy for i in range(self.num_channels)]
1243 await self.initialize_pipetting_channels(
1244 x_positions=[extended_conf["xw"]], # Tip eject waste X position.
1245 y_positions=y_positions,
1251 discarding_method=0
1252 )
-> 1254 iswap_initialized = await self.request_iswap_initialization_status()
1255 if self.iswap_installed and not iswap_initialized:
1256 await self.initialize_iswap()
File ~/pylabrobot/pylabrobot/liquid_handling/backends/hamilton/STAR.py:6121, in STAR.request_iswap_initialization_status(self)
6114 async def request_iswap_initialization_status(self) -> bool:
6115 """ Request iSWAP initialization status
6116
6117 Returns:
6118 True if iSWAP is fully initialized
6119 """
-> 6121 resp = await self.send_command(module="R0", command="QW", fmt="qw#")
6122 return cast(int, resp["qw"]) == 1
File ~/pylabrobot/pylabrobot/liquid_handling/backends/hamilton/STAR.py:1172, in STAR.send_command(self, module, command, tip_pattern, write_timeout, read_timeout, wait, fmt, **kwargs)
1158 async def send_command(
1159 self,
1160 module: str,
1167 **kwargs
1168 ):
1169 """ Send a command to the machine. Parse the response if `fmt != ""`, else return the raw
1170 response. """
-> 1172 resp = await super().send_command(
1173 module=module,
1174 command=command,
1175 tip_pattern=tip_pattern,
1176 write_timeout=write_timeout,
1177 read_timeout=read_timeout,
1178 wait=wait,
1179 **kwargs
1180 )
1181 if fmt != "":
1182 parsed = parse_star_fw_string(resp, fmt)
File ~/pylabrobot/pylabrobot/liquid_handling/backends/hamilton/base.py:191, in HamiltonLiquidHandler.send_command(self, module, command, tip_pattern, write_timeout, read_timeout, wait, **kwargs)
170 """ Send a firmware command to the Hamilton machine.
171
172 Args:
186 A dictionary containing the parsed response, or None if no response was read within `timeout`.
187 """
189 cmd, id_ = self._assemble_command(module=module, command=command, tip_pattern=tip_pattern,
190 **kwargs)
--> 191 return await self._write_and_read_command(id_=id_, cmd=cmd, write_timeout=write_timeout,
192 read_timeout=read_timeout, wait=wait)
File ~/pylabrobot/pylabrobot/liquid_handling/backends/hamilton/base.py:215, in HamiltonLiquidHandler._write_and_read_command(self, id_, cmd, write_timeout, read_timeout, wait)
213 fut = loop.create_future()
214 self._start_reading(id_, loop, fut, cmd, read_timeout)
--> 215 result = await fut
216 return cast(dict, result)
TimeoutError: Timeout while waiting for response to command R0QWid0006.
If I understand the error message correctly, the setup was checking for the existence of an iSWAP but instead of returning None, as it was supposed to, it raised a TimeoutError?
This might be a very simple problem but digging into the PLR codebase I couldn’t find the solution.
Thank you for your help.
