Retrieving Sub-Method Name
Hi everyone,
Is it possible to retrieve the name of the current sub-method running?
I’m building a sub-method library with functions that can be called by methods, but also by sub-methods within itself. I’d like to be able to detect whether or not the function call is external or internal without having to ask the user configuring the step within a method. Does anyone know if this is possible?
E.g.
Example 1 - Method 1 > Sub-method Library A > Function X
Example 2 - Sub-method Library A > Function Y > Function X
Was Function X called by Method 1 or Function Y?
Many thanks for any help!
Will
Hi @WillEb ,
You can retrieve the submethod name using the HSL command GetFunctionName(). You just need to initialize a variable outside of the code to pass it to the method for you to use. See below:
Thanks Brandon - that’s really helpful.
Will
That’s what I thought too, initially, but its not quite what Will needs? GetFunctionName() will return the submethod name, in which case for his example, will always return “Function X”…
I’m interpreting it as pass the output of GetFunctionName() to FunctionX as an argument
Followup Question @BrandonBare_Hamilton; is there a way to retrieve the SubMethod Description or the Parameters in the Parameter list as well?
