What’s up with this feature? Do you use it?
I tried it out for funsies and it behaved in an interesting manner.
A while ago I tried the T;… worklist command just to see how it works. It had pretty much the same parameters as the Sample Transfer script command and I preferred to use the script command.
Did you try it with the Excluding wells with parameter?
No I didn’t try the optional Excluding Wells Parameter
