Hello, recently my Run Control has stopped showing labware/wells as they are accessed during simulation runs. Empty carriers do appear on the deck, but as the method runs no labware appears or is highlighted to demonstrate it is being accessed (program is otherwise running from the trace and method views). No settings were intentionally changed for this, can anyone advise? Thanks!
Hi @brt110 ,
Can you specify the version of VENUS you are running? If you browse to the Hamilton\Bin folder you can run the HxVersion.exe program that will give the specific version you are running.
This will help diagnose what might be going on here.
