%load_ext autoreload
%autoreload 2
from pylabrobot.liquid_handling.backends.simulation.simulator_backend import SimulatorBackend
from pylabrobot.resources.hamilton import STARLetDeck
sb = SimulatorBackend(open_browser=False)
lh = LiquidHandler(backend=sb, deck=STARLetDeck())
await lh.setup()
from pylabrobot.resources import (
    TIP_CAR_480_A00,
    PLT_CAR_L5AC_A00,
    Cos_96_DW_1mL,
    HTF_L
tip_car = TIP_CAR_480_A00(name='tip carrier')
tip_car[0] = tips = HTF_L(name='tips_01')
tip_car[1] = HTF_L(name='tips_02')
tip_car[2] = HTF_L(name='tips_03')
tip_car[3] = HTF_L(name='tips_04')
tip_car[4] = HTF_L(name='tips_05')
lh.deck.assign_child_resource(tip_car, rails=15)
plt_car = PLT_CAR_L5AC_A00(name='plate carrier')
plt_car[0] = plate_1 = Cos_96_DW_1mL(name='plate_01')
plt_car[1] = plate_2 = Cos_96_DW_1mL(name='plate_02')
plt_car[2] = plate_3 = Cos_96_DW_1mL(name='plate_03')
lh.deck.assign_child_resource(plt_car, rails=8)
This code doesn’t seem to update the simulator I’m running. I’m SSH’d into a computer running the simulator locally and forwarding the ports 1337 and 2121.
EDIT: When I run the notebook locally it works, so it’s probably some issue with the port forwarding. I notice that the websocket port seems to iterate every time i call llh.setup - perhaps i need to forward every single one of the ports that it opens? Unsure.
Any idea what might be going wrong? Thanks.
