Snugly Positioning a Plate on the Biomek Deck
Hi gang,
I recently started working with a Biomek i-series robot. There’s a bit of slack in the X and Y for a standard well plate sitting on the deck. I’m guessing this is to avoid issues with the plate gripper.
I have an application that requires highly repeatable positioning of a piece of labware on the deck. It doesn’t move often, and it doesn’t need to interact with the gripper. My current solution involves pushing the labware to the A1 corner of its nest when I place it on the deck. I need something more permanent.
Has anyone encountered this situation before? Any solutions?
Any special ALPs available? orbitals clamp towards A1, or alternatively some adapter on a coldplate could also reduce movement.
I think this might be more of a labware problem than an ALP problem. Beckman do have something called a ‘positive positioning ALP’ though for things such as this.
You can have the robot push the plate for you by programming your own own pipetting template or using a tip touch command to push it towards 135 degrees (A1).
