Tecan Fluent Control Liquid Classes
I am a pretty new Tecan Fluent user and working on building some methods to automate some of our manual sample prep procedures in our lab.
I’ve managed to figure some things out and am getting some working scripts. However - my initial runs are showing significantly higher imprecision than manual prep - which is very disappointing. I am thinking this may be related to the addition of the internal standard but not totally sure. And I am fumbling around in the dark a little bit when it comes to what parts of the liquid class can be adjusted in order to improve precision and accuracy.
Here are a few of my questions:
(1) For a multi dispense LC: would I want a trailing air gap? Since it’s repeat dispensing, wouldn’t this mean the first dispense would have less volume than the rest since it would include the TAG? Or is the ‘TAG’ checkbox in the dispense step meant to deal with this?
(2) if a multi dispense (ie - Reagent distribution function) has observable droplets on the tips - how would I fix this? I am using the ethanol free multi LC as a starting point for my internal standard solution in methanol.
(3) Would it be better to do multiple aspirate/dispense steps (ie like using a variable pipetting loop) rather than a reagent distribution for more volatile solvents like methanol?
Thanks very much to anyone who can give me some advice!
Hi GV,
If you care a lot about precision and accuracy I would always go for single aspirate/dispense.
I don’t work with as volatile solvents as methanol so I will reframe from giving you particular advice.
Hamilton does an excellent job of handing out information about liquid classes here on this forum, and IMO much of it is transferable to Tecan Fluent.
Page 54
Page 55
Definitely utilize the Hamilton Liquid Handling Guidebook - it is a great resource to have. Other than that, I’d recommend starting with the basics first. LC in FluentControl can be massive rabbit holes and you don’t often need to level of control that microscript offers for every liquid type. Start with simple things like aspiration/disp speeds, delays, retract speeds, and touch-offs.
A validation approach that has been working well for me is to first define your needs, translate that into single vs multi, tip sizes, and volume ranges, then fine-tune your LC starting with highest volume aliquots to visually check for droplet formation and clean/even delivery. Move to gravimetric testing with replicates across the whole range of volumes to fine-tune your calibration (accuracyadjustment()).
There are some hidden functions in fluentcontrol that will be useful - you’ll want to use the help manual and navigate to operands and functions to better understand what tools you have available. Similarly, there are some hidden attributes such as X_TIP_TOUCH and Z_LIQUID, Z_BOTTOM, etc that are useful. It’s been a minute since I’ve used FC but I be sure to look at default LC for clues on what tools are available.
@J_Evans submitted a great rundown on LC optimization in an earlier post. The whole thread is worth a read. https://forums.pylabrobot.org/t/liquid-class-optimization/135/24?u=evwolfson
EDIT: Quick update for my own $0.02 on your questions:
Use TAG if droplets are seen, but be aware that they add to your tip volume capacity and can affect how many aliquots can be transported at once. The TAG is aspirated after the entire liquid column, including multiple aliquots. For multidispense, your excess volume will be handled with conditioning and overage to (respectively) provide excess volume for 1st and last dispenses.
Good starting point - play with retract speed to find the balance between limiting vapor pressure buildup and the effect of quick movement on liquid equilibrium within the tip. I often variablize delay and retract speed within microscript to make changes easier. I’d also recommend a significant pre-wet and delay to equilibrate temp and pressure. A single dispense or significant overage may be required for this liquid.
Probably, yeah. In general variable pipetting loop will give you better control, but once you find a solution you can fine-tune microscript and utilize reagent distribute smart-steps for implementation. A trick I often used was to create an LC called “Do_Nothing” that did literally nothing and set that as my LC for dispensing excess to waste which reduced loss between aliquots when using reagent distribution smart commands - might be useful if you need to use individual transfers rather than multi.
As a last comment - ask Tecan Helpdesk. They may have some engineers that have run into this problem and can provide LC for you - which may work but at worst case would provide a template to learn from.
Thank you! I used a Hamilton StarLET for 11 years, and honestly didn’t have to play around with LC’s much at all - I usually had to add a pre-mix step before multiple asp/dispense and that typically improved precision.
I will review the Hamilton LC info - thanks so much for your feedback!
Thank you so much for your detailed reply. ‘LC in FluentControl can be a massive rabbit hole’ - don’t I know it - just from my few months playing around - I feel this!
It’s super inconvenient for me to do gravimetric testing as our balances are down the hall in another room - but I was thinking yesterday as I was writing my post that this is what I think I will have to do at this point.
Really appreciate your experience and advice - very helpful, and the link to the other LC post which I will review now.
