Tecan Fluent Import Error
I’m trying to import an instrument file (.zeia) into Tecan Fluent Control. I’m getting an error ID: VX_DTAST_001_050 with the description “Found invalid data while decoding”. I need help to determine what the root cause of this error is and how to fix it. Thank you!
Update: I suspect that the initial export file (.zeia) was corrupted. I made a new export from the same Fluent 780 and was able to successfully import onto a different PC
