We have an intermittent issue on a STAR instrument with CORE I tech. Occasionally tips fall off the 8-span or are not successfully ejected. Maintenance tests pass with no errors.
Should we replace the CO-RE stop discs on the STAR as described there? Using the same Part Numbers? Has anyone seen similar behavior? Is this an issue related to CORE I? Or CORE I using CORE II tips?
CO-RE I stop discs are compatible with CO-RE II tips, which we have been shipping for years now.
What is not compatible are CO-RE II stop discs with CO-RE I tips.
It sounds like your issues require technical support, which may include replacement of the CO-RE I stop discs. Tips should never fall off given the lock/key mechanism of CO-RE technology so something is interfering.
Could you please share the PNs for the CO-RE I 8-span stop discs and changing tool, assuming they are different from the ones specified in the article I shared above?
