We have the prep for couple of years working just fine. All of a sudden on a Thursday morning the onboard pc cannot detect the instrument, an error I never encountered before. Our local distributor is checking that with Hamilton, but I wondered if anyone tackled this issue. The repair tool doesn’t work in this case, it tries to install a firmware from file but fails.
Hi Isaac, thanks for writing in this forum. I am a part of the US team with Hamilton and would love to offer some assistance while you wait to hear from your local distributors. Can you give this a try?
Select continue without instrument. then go to Settings> Instrument> Configuration, and select instrument. You should choose their serial number…
If that does work, try power cycling and connecting again.
Hi Isaac, thanks for the information. Because these steps did not resolve your event, we recommend working with your distributor to work with Hamilton Support to resolve this technical event. Please let me know how it goes!
Not sure if this is related, but I recently had a similar error where the computer became disconnected from the instrument. We had to reset the network to factory settings by pressing the power button in succession 3 times and then holding until the instrument started blinking green.
If the issue has not yet been resolved, I can try to type out some in depth instructions (that were given to me some time ago from a US Hamilton Rep), unless @LissetteB might know more about this error
The reset noname describes sounds worth trying, but before doing it, record the instrument’s current IP/subnet/gateway and any static network settings—factory network resets often clear them, and you’ll need the original values to restore connectivity. If possible, also connect a laptop directly to the instrument’s network port and see whether it responds. That helps separate an onboard-PC/network-stack problem from the instrument itself. Since your distributor is already involved, run the reset steps past them or Hamilton first so it doesn’t complicate their remote diagnosis.
