Hi there, Im having some troubles with the RGA not transfering correctly in to my platereader “nest” I tried using the “transfer” way, where you place the RGA at the spot and then press transfer to locate the place on the worktable, however this is not working. Then i tried changing the X, Y and Z numbers but the errors i get does not at up at all. It is just saying “RGA out of range” no matter how i change it.
Do you know how it is functioning or is it just pure guess work?
By the way, my fluentcontrol software is 2.5
Hope you can help me
