UV light on Hamilton STAR
does anyone know how to turn it on? :sweat_smile:
not a complete answer, but maybe a first step:
On Vantage (next generation of STAR) there is the following:
return await self.send_command(
      module="C0AM",
      command="LI",
      li={
        "on": 1,
        "off": 0,
        "blink": 2,
      }[mode],
      os=intensity,
      ok=blink_interval or 750, # default non zero value
      ol=f"{white} {red} {green} {blue} {uv}",
From VStarTranslator.log (it appears that “Venus on Vantage” just translates firmware commands to the vantage language)
C0STid0135sp100sf2so1sj000 -> C0AMLIid0135li1os100ol0 0 100 0 0
could sf be an index into the 5-tuple for wrgbu? Command ST is undocumented in C0.pdf… would love to hear what you find out.
(safety warning: uv is dangerous)
It is controlled via a library that is also used for the HEPA filters. I’m sure @NickHealy_Hamilton or @EricSindelar_Hamilton can help you out here.
Actually depend on machine and model. but both have a button or touch screen to turn it on and off. Also the HEPA library works for that.
hm, no luck. Tried:
await lh.backend.send_command(
    module="C0",
    command="ST",
    sp=100,
    sf=2,
    so=1,
    sj=000
And got
STARFirmwareError: {'Master': CommandSyntaxError('Unknown command')}, C0STid0010er01/30
Me and a coworker have looked over the whole machine and haven’t been able to find any such switches :upside_down_face:
(obvious suggestion) i take it there is no venus option for this
I don’t know how to use venus :sweat_smile:
@dominik.b @Kalpesh can you provide me with a link to download the HEPA library? I’m looking here Lab Automation Forums :: Hamilton but can’t seems to find it.
@EricSindelar_Hamilton do you have any insight into this? :slightly_smiling_face:
Tomorrow I can check on my machine which command is sent to the machine to switch on/off the lights.
that would be amazing :slightly_smiling_face:
There are a few different UV kits we’ve offered some of which are part of a HEPA assembly. It sounds like you may have a standalone unit? Does it look like the image below with just the light on top and the front UV shield for the autoload opening?
Yes, it looks just like that!
See this link for the installation and user manual. Per the manual, the installation of the STARline UV light kit should only be performed by a trained service engineer.
See this link for the software to control the UV.
wow, incredible, thank you!!
Hmm, I’ve enabled cover monitoring as suggested.
But I can’t seem to get past
I’m not sure what the best steps are as typically these are installed by a Hamilton Field Service engineer. You can try following up with tech@hamiltoncompany.com to see if they can assist.
the unit came pre-installed on the system, we just don’t know how to use it
To my knowledge, Hamilton does not pre-install UV kits and ship them with the system - instead, they are installed onsite. If it was purchased from Hamilton, then please send me a direct message so we can resolve.
