Hi, I would like to ask anyone here have experience with Vanquisher driver control with Cellario? What is your experience like to connect with it? How to make the connection stable?
We are currently also considering putting a Vanquish on a HRB workcell.
Do I understand this correctly that you have this setup installed and are not happy with the performance of the driver? Can you share any details about your setup and the problems you observe? Do you run the Vanquish with a fraction collector for example for automated SEC or do you run connected LC-MS protocols?
Hi Novice,
We are using SEC column with fraction collector. We have not tried to run the HPLC with any method yet but in the process of testing the mechanical movement with dry run. Testing the side door panel and integration with HPLC.
thanks a lot for getting back. that is exactly what we plan to do as well so super interested in your experience with this setup. what problem do you currently have with the driver?
