The BC section of this forum is looking pretty sparse, but I’m betting we have some good resident experts out here. I have I problem that I think has an easy solution, but I’m not having any luck figuring this out on my own.
I’m trying to add procedures to control repeatable tasks of asp:disp cycles into varying types of labware. The problem is that I can’t figure out how to change the labware type dynamically. This value doesn’t seem to update to the correct labware when the ALP pos is set as the target, which (as I understand it) affects labware dimensions, well dimensions, etc…
I imagine the issue is that this is a dropdown list rather than another type of entry field so I’m unable to modify the source list. I’ve looked into the super-secret scripting elements, and this field is at Root > items > 0 > LabwareClass but as before, this field cannot accept a variable as input and instead interprets any entry here as literal/raw, so it would try to find a plate called “=LabwareType”, for example.
Anyone know for certain if this is attainable or if this is a lost cause?
