I’m working on a python based OPC-UA client to communicate and run a Vi-Cell Blu. I’m able to properly connect, receive information from the device, and send commands like setting the automation lock on and off. For some reason, I cannot get it to run an automation cup sample. Does anyone with any experience with the Vi-Cell Blu driver know what issues could be causing this?
Below is the code I’m currently using to communicate:
client = Client(URL)
client.application_uri = "urn:vesalius:robocell:client"
client.set_user(USER)
client.set_password(PASS)
client.set_security_string(f"{POLICY},{CERT_DER},{KEY_PEM}")
client.connect()
c_methods = client.get_node("ns=2;i=15272")
play_control = client.get_node("ns=2;i=15309")
start_sample = client.get_node("ns=2;i=15310")
data_classes = load_type_definitions(client)[1]
data_enums = load_enums(client)
valid_cell_types = vc_methods.call_method("2:GetCellTypes")
sample_cfg = data_classes["SampleConfig"]()
sample_cfg.SampleName = f"Test_sample_{int(time.time())}"
sample_cfg.SampleStatus = data_enums["SampleStatusEnum"]["NotProcessed"]
sample_cfg.Dilution = 1
sample_cfg.CellType = valid_cell_types.CellTypes[0]
sample_cfg.Tag = "testing"
sample_cfg.SaveEveryNthImage = 1
sample_pos = data_classes["SamplePosition"]()
sample_pos.Column = 1
sample_pos.Row = "A"
sample_cfg.SamplePosition = sample_pos
lock_resp = vc_methods.call_method("2:RequestLock")
result = play_control.call_method("2:StartSample", sample_cfg)
vc_methods.call_method("2:ReleaseLock")
client.disconnect()
When trying to run the sample I get back the error: ‘Failed to process SampleSet ‘Automation Cup Sample Set’: NoSamplesDefined, InvalidStageAndCarrier, CarrierNotDefined, InvalidSamplePosition, ErrorLevel: ErrorLevelEnum.Error’
If I instead try to run the method StartSampleSet, with the same sample config in an array, it runs with no issue. I’ve also tried different variations of the SamplePosition variable, both the default value and a None value, both create errors as well.
I think there must be some issue with the way the Vi-Cell is configured in this communication but I’m not sure how to change it.
