I truly have no idea what is happening. There is a longer story and some other details I can get into, but it’s hard to make sense of them all.
The short story is this might have something to do with the jet dispense step, but might not.
I came in this morning and made some minor changes to the code after reading the note from @rickwierenga. That code is pasted below for your viewing pleasure. This code worked just fine right away and I had no problems even going up to the same volumes as the code yesterday. The only two changes I made:
- I changed the
jet=True to blow_out=True (but had actually done this yesterday and was getting the error.) This is also in the dispense step prior to the error-inducing mix step.
- I noticed I was mixing floats and ints when calling volumes. I know PLR corrects for int calls, so I changed them all to ints to be consistent.
I then tried to run exactly the same code from yesterday and immediately got the error. I then re-ran the “good” new code without error. I then ran the old “bad” code and did not get the error, even running it many times in succession.
To sum up, what I seem to be able to reproduce is:
pick up tips
run "bad" code => get error
run "good" code => no error
run "bad" code => no error
drop tips
and
pick up tips
drop tips
Something in the original “bad” code is causing an issue, and running the new “good” code is fixing it, seemingly indefinitely.
Now, I have the functioning code and it works for me so I can continue working on this process, but I leave this all here for people to think on. I’m happy to keep experimenting to figure things out, let me know. For reference here again are the code blocks:
Bad:
await lh.aspirate96(lh.get_resource('alpha_plate').get_quadrant(3), volume=2.0,
flow_rate=2.0,
transport_air_volume=0,
pre_wetting_volume=0,
offset=Coordinate(x=1.5, y=1.5, z=-2.5))
await lh.dispense96(lh.get_resource('alpha_plate').get_quadrant(4), volume=2.0,
flow_rate=2.0,
jet=True,
offset=Coordinate(x=1.5, y=1.5, z=-0.5))
await lh.aspirate96(lh.get_resource('alpha_plate').get_quadrant(4), volume=0.0,
flow_rate=2.0,
homogenization_volume = 8,
homogenization_cycles = 2,
speed_of_homogenization = 8,
offset=Coordinate(x=1.5, y=1.5, z=-2))
Good:
await lh.aspirate96(lh.get_resource('alpha_plate').get_quadrant(3), volume=2,
flow_rate=4,
offset=Coordinate(x=1.5, y=1.5, z=-3))
await lh.dispense96(lh.get_resource('alpha_plate').get_quadrant(4), volume=2,
flow_rate=4,
blow_out=True,
await lh.aspirate96(lh.get_resource('alpha_plate').get_quadrant(4), volume=0,
flow_rate=8,
homogenization_cycles = 4,
