I am using a lot of 300µL Wide-Bore 1.55 tips for mixing in one of my cell assays. I have tried to manually move tips from standard racks to NTR’s, as these are not available in NTR format.
The problem is that these special tips are shorter and wider inner diameter - so when in a stack of 4, they often stick together (tip-on-tip) which is not good.!
Does anyone have experience or a hack to store a lot of wide-bore tips on deck.?
I should say I’m limited in space on deck.
Hope some can help with some input.
Kind regards,
Rasmus
