For DiTis is you use a worklist generator command to go from csv to gwl it still seems to pick a tip for a 0 volume, the way I have programmed it with dynamic DiTi handling. Is it possible to use dynamic handling and avoid picking up tip when it reads a 0 value?
i was unable to get this function to work using the std worklist csv>gwl conversion
i went with a custom gwl generator to only write trigger a tip pickup, aspirate x y, dispense x z, tip drop where volume was > 0 uL
this mechanism also allowed to force specific tip types to be used
Thanks
