What’s the easiest/best way to define a simple water beaker on the deck with some volume or height of liquid inside?
I see the OT-1 has documentation on adding containers. Is there something equivalent for the OT-2? Using the Custom Labware Creator seems overkill for a simple water beaker.
I always just use the custom labware creator, it’s not very difficult to use and with a caliper you can fill in all the boxes easily
Thanks! Do you know of a programmatic way to load custom labware?
I just do this
waste_trough = protocol.load_labware(“agilent_1_reservoir_300000ul”, 10, label=“waste_trough”)
And I load the .json from the custom labware creator on the machine. Otherwise to simulate make sure the .json is in the folder you’re running the .py from
The labware creator is the best way to create custom labware. At some point, there was a CLI labware creator tool on Opentrons’ GitHub that would allow you to create labware that couldn’t be made in labware create (uniform wells, tubes/wells of different volumes, etc.). However, I am not able to find it anymore.
