Fluent Control - FCA1 Mix
Has anyone been using the Mix command with the Water Mix liquid class on FCA 1 and also run into this error: “InnerException: Specified argument was out of the range of valid values. Parameter name: height”?
I’m mixing in a 96 well plate that can hold a maximum of 350 uL per well. I’ve been mixing with 150 uL in wells that have a total of 300 uL. I’ve tried adjusting all of the Z-Coordinates in my microplate labware but always still seem to end up encountering into this error somewhere in my script.
This might be the post to look at :smile:
The error seems very simelar and EricScheitz_Tecan does a good job at explaining the fix.
Ah yes this is what I was looking for. Thank you!
