I am having the following error on our Hamilton Vantage;
“I1: Scanner X-drive initialization failed”
Which appears similar to the following problem previously identified in the following thread;
Initialization errors - Hamilton (Venus) / Venus Questions - Lab Automation Forums
Is there an easy way to disable this step in the initialization if the autoload and barcode scanner are not actively used by any method?
Thank you!
