Opentrons Flex Moving of Custom Labware
Has anyone had success stacking and moving custom labware on the
Flex deck?
So far all we know is that a “lid” and “delid” function using pick_up_offset and drop_offset might be used in combination with a stackingOffsetWithLabware and stakingOffsetWithModule added to the labware definition files. Our attempts have been unsuccessful with this approach and led to calibration crashes.
Hey @kostrouc - we have a few users who are hacking this right now. If you haven’t figured out a solution, let me know, and I’ll put you in touch. We’re also working on making this a core function in our API.
Hey there @kostrouc , any updates on this? I am attempting a similar thing now and am a bit dissatisfied that it isn’t a core part of the api.
Hello @kostrouc
I literally just threw this code together yesterday for a quick test of what you asked here since our machine got delivered a few days ago. I used the labware height of my wellplates as a reference and just kind of had to adjust it with a little bit of trial and error, but it ended up working just fine!
If you have any questions around it let me know! The key is to just only have one labware loaded on the deck at a time, and this requires deleting the labware periodically so you don’t get errors that it already exists or that the slot is occupied
        temp_plate_source = protocol.load_labware(
        "corning_384_wellplate_50ul", location="D4"
        pickup_offset_for_plate_2 = {'x':0,'y':0,'z': z_height_corning-1.5}
        dropoff_offset_for_plate_2 = {'x':0,'y':0,'z': z_height_corning+1.2}
        protocol.move_labware(temp_plate_source, "D2", use_gripper=True, pick_up_offset=pickup_offset_for_plate_2, drop_offset = z_height_default)
        ### plate now on D2
        ## Remove lid
        protocol.move_labware(temp_plate_source, "D3", use_gripper=True, pick_up_offset=lid_offset, drop_offset = z_height_default)
        del protocol.deck["D3"]
        "corning_384_wellplate_50ul", location="D2"
        # Do pipetting Actions here
        # Delete plate and reload lid
        "corning_384_wellplate_50ul", location="D3"
        # Put lid back on labware
        protocol.move_labware(temp_plate_source, "D2", use_gripper=True, pick_up_offset=z_height_default, drop_offset = lid_offset_drop)
        # Put labware into "done" stack
        protocol.move_labware(temp_plate_source, "C4", use_gripper=True, pick_up_offset=z_height_default, drop_offset = z_height_default)
        del protocol.deck["C4"]
        # Move next plate to pip loc
        protocol.move_labware(temp_plate_source, "D2", use_gripper=True, pick_up_offset=z_height_default, drop_offset = z_height_default)
        ### plate 2 now on D2 #####################3
        ## Remove lid
        del protocol.deck["D2"]
        protocol.move_labware(temp_plate_source, "C4", use_gripper=True, pick_up_offset=z_height_default, drop_offset = dropoff_offset_for_plate_2)
        ## Purely curious, can we move the stack alltogether?
        protocol.move_labware(temp_plate_source, "D4", use_gripper=True, pick_up_offset=z_height_default, drop_offset = z_height_default)
        ##A:  Yes we can :)))
Is there a way to delete labware when its on a module? Or is there a way to do move_labware without the gripper and without pausing for the user to do it…
(I’m trying to put a lid on a well plate after moving it onto a temp module :sweat_smile: del protocol.deck() doesn’t let me do it when it’s on a module!)
Hey @hkjawn
I have not successfully done it. But if you “move” it somewhere else, you can delete it as a workaround
I wonder if there’s an option to move something off-deck without using the gripper, while also not needing a pause in the protocol. :thinking:
I digress! I’ve been thinking and I suppose a possible workaround to getting a lid onto a plate that’s in the module would be:
  1. Grip the upper part of the plate sans lid, move it to an empty slot (because the bottom part of the well plate is covered by the temp module)
  2. replace_lid()
  3. Move plate + lid back onto the module
In my cell culture case, I’m trying to incubate the well plate with trypLE at 37C on the temp module, then move if off to continue processing. However, as I’m typing this out I’m realizing… maybe I don’t need to move it on/off the temp module, I could just leave it on there the whole time and just adjust the module’s temp! (Except I still can’t replace the lid after removing it so there may higher-than-desired evaporation during the 10 min 37C incubation step - maybe the amount would be insignificant?)
I hope you figured it out, I’ve been absent from the internet for a while! Any updates? :slight_smile:
Also @kostrouc how’s it going in your flex journey?
I ended up just finetuning the offsets just right to move the plate + lid, grabbing the narrow lower lip of the plate. This allowed me to move the plate with the lid on! (Instead of moving the lidless plate then adding the lid on afterwards)
Don’t be shy, share gifs of your triumph!
It turns out I did video it previously when I was testing things out (this is of the default corning plate, but I’ve also done it with my custom labware, a coverslip bottom Cellvis 96 well plate):
VID_20260226_125731-ezgif.com-optimize
Also finally migrated to using move_lid() now that it’s been added to the API. But huge shout-out to @Shinedalgarno for enabling lid handling for us prior to this!
Also, seems like one corner of the corning well plate lifts up when shaking - not really an issue for me as I only need to shake for a few seconds…
We are currently using the Opentrons Flex and exploring ways to extend its capabilities for high-temperature reactions beyond the standard modules.
We’re specifically looking for a heating solution with the following requirements:
  • Compatible with Flex deck (ANSI/SLAS SBS footprint)
  • Temperature range up to ~200°C
  • Suitable for glass vials or sealed reaction tubes
  • Can operate on-deck during automated workflows
  • Compatible with 220V (India)
From what I understand, the existing Opentrons temperature module typically supports only much lower ranges (e.g., cold/ambient to ~95°C) , so we’re exploring alternatives.
Would really appreciate inputs on:
  1. Any existing module or workaround people are using
  2. External integrations (e.g., off-deck heating + automation sync)
  3. Custom-built solutions (if anyone has attempted this)
  4. Vendors or recommendations for custom manufacturing
