ParseDateTime() + FormatDateTime() Functions
Seems silly, but I have to ask why this isn’t working. I have tried to generate the long integer output, yet Touch Tools preview isn’t generating the expected output. I have tried many formats (see below, I won’t bore you with all of them). Ultimately I want the date() + time() values to be output for naming a CSV file automatically. However the time() output uses colons (:), and a filename cannot have colons. Any help with the syntax here would be appreciated. I can’t get the Help documentation example to work!
ParseDateTime(“Jan27-2019”,“MMMdd-yyyy”)
ParseDateTime(“Jan27-2019”,“MMMDD-yyyy”)
ParseDateTime(“Jan27-2019”,“MMMdd-YYYY”)
ParseDateTime(Jan27-2019,“MMMdd-yyyy”)
ParseDateTime(Jan27-2019,“MMMDD-yyyy”)
ParseDateTime(Jan27-2019,“MMMdd-YYYY”)
Parsedatetime(“Jan27-2019”,“MMMdd-yyyy”)
Parsedatetime(“Jan27-2019”,“MMMDD-yyyy”)
Parsedatetime(“Jan27-2019”,“MMMdd-YYYY”)
Parsedatetime(Jan27-2019,“MMMdd-yyyy”)
Parsedatetime(Jan27-2019,“MMMDD-yyyy”)
Parsedatetime(Jan27-2019,“MMMdd-YYYY”)
Image screenshot below from the F1 Help documentation, Fluent Control Ver 3.7
And what does “double” denote here. I also see “MM” in the place of minutes, which should be “mm”, so now I’m loosing faith in the help documentation.
i’ve always used substring function for date & time, to then concat the required format, with “-” or “_” as needed
You can always strip off the colons using the substring function.
For getting the value of the function into TouchTools, if you save it to a variable first, then display the variable in TouchTools, it works. Example code attached.
Mike Mueller
The following works fine for me with CSV:
Was set up for my first script and then never touched and only copied… :smiley:
@Dirk , Thanks! That looks a lot cleaner then my mess below:
For reference, this is what I heard back from Tecan (below). I’ve nested their functions, ensured “myTimeStamp” was a string variable, and it worked as expected.
Nested functions within Set Variable:
Thanks for sharing their solution. Nice to see the step by step of the nesting.
I personally use a similar approach as @Dirk. Set it as a subscript and call it from other scripts as needed.
