Pipette Tip Eject Failure w/ Video (Hamilton CO-RE II)
My STAR has recently been failing to fully eject pipette tips once every ~500 tip pickups. The problem is not localized to any channels, and there’s no residue on the channels that they might be sticking to. I’ve heard others may have had this issue and that it could be related to static electricity clinging. We run our robots in a pretty dry environment so static cling would likely be worse in our case.
The tips are clear 1000uL filtered and non-filtered. I plan to update with lot #s when I can. I’ve attached a video that captures the behavior we’ve seen quite consistently.
I was wondering if anyone else has seen similar behavior on their Hamiltons (specifically CO-RE IIs) or any other robot for that matter and if the cause is likely to be static.
@Stefan When was your last PM on the unit? Sometimes the orings can cause this issue.
Less than two weeks ago, my understanding is that CO-RE II does not use o-rings for tip pickup and eject though
@Stefan Right. Sorry about that. Is your lab dry? Maybe static?
Yeah our humidity is <30% which seems to be the threshold where static occurs
Sorry to hear about the issue. Ejecting back to a tip wafer doesn’t give you the added benefit of the “roll-off” behavior seen on eject on the tip eject tray to waste. You could try implementing a firmware command PXAA ts1 to add more up and down z movement on the eject which may help mitigate the tip cling. You can send the command at the beginning before the eject step and then disable it at the end and On Abort (use ts0).
Please provide the tip lot information when you can and send me a recent run trace so I have the system SN, software, and firmware versions (you can DM me with that info). I can follow up internally once I have more information!
Thank you!
Eric
Ill try it out, much appreciated
I should add that you should put a move to sequence prior to initially sending the command as it actually does a tip shake wherever the channels are when you initially execute the command. Just to be on the safe side. When you later use the standard tip eject command it will do this additional tip shake.
In other words, the move command only needs to be set right before the first use of the firmware command.
Here’s a few things to check out.
  1. Make sure the carriers are wiped down and cleaned on a regular basis. Dust a debris can isolate the carrier from the ground plane of the machine allowing a static charge to build up and cause these issues.
  2. Bring the humidity in your lab up. The minimum specification from Hamilton for these units is 30% humidity. Operating below that can cause static issues as well as premature o-ring failures/cracking.
  3. Get a small ionizer to blow over the deck. They sell a few models on Amazon.
  4. If your system has the spill protection kit installed have your tech inspect the underside of the deck during the next pm. I have seen a number of these kits installed improperly where the green tape on the underside of the deck is in the area where the deck “should” be contacting the steel frame. This can also cause isolation and static buildup on the deck plane.
Just a few thoughts! Good luck!
Ionizer might be the way to go
@EricSindelar_Hamilton @smores Lot # is 1099942
I second this. It doesn’t matter which vendor you have, everyone should monitor temp/humidity and install a small ionizer as an insurance policy if possible.
I’ve used this brand in the past ( link 1 & link 2 ) and was well worth the money.
Ah nice that’s the same as what we just bought. I never realized this was an issue, never seen it before personally over years in the field.
Serial commands are:
22:54:28.770 8AF#8000#00: C0RLid0933er00/00lh+0000 +0000 +0000 +0000 +0000 +0000 +0000 +0000
< 22:54:29.464 8AF#8000#00: C0RXid0934
22:54:29.487 8AF#8000#00: C0RXid0934er00/00rx+06535
< 22:54:29.491 8AF#8000#00: C0ASid0935at0&tm1&xp06535&yp2420 2330 2240 2150 2060 1970 1880 1790th2450te2450lp2001&ch000&zl1921&zx1871&ip0000&it0&fp0000&av00062&as2500&ta050&ba0000&oa050&lm0&ll1&lv1&ld00&de0020&wt10&mv00000&mc00&mp000&ms3500&gi000&gj0gk0zu0113&zr09285&mh0000&zo000&po0000&lk0&ik0000&sd0500&se0500&sz0300&io0000&il00000&in0000&
22:54:33.710 8AF#8000#00: C0ASid0935er00/00
< 22:54:33.792 8AF#8000#00: C0RLid0936
22:54:33.839 8AF#8000#00: C0RLid0936er00/00lh+0000 +0000 +0000 +0000 +0000 +0000 +0000 +0000
< 22:54:34.552 8AF#8000#00: C0RXid0937
22:54:34.574 8AF#8000#00: C0RXid0937er00/00rx+06535
< 22:54:34.577 8AF#8000#00: C0DSid0938dm3&tm1&xp05610&yp2100 2010 1920 1830 1740 1650 1560 1470zx2050&lp2180&zl2100&ip0000&it0&fp0000&th2450te2450dv00066&ds5000&ss2500&rv000&ta000&ba0000&lm0&zo000&ll1&lv1&de0020&mv00000&mc00&mp000&ms3500&wt00&gi000&gj0gk0zu0113&dj00zr09285&mh0000&po0000&
22:54:37.880 8AF#8000#00: C0DSid0938er00/00
< 22:54:37.941 8AF#8000#00: C0RLid0939
22:54:37.988 8AF#8000#00: C0RLid0939er00/00lh+0000 +0000 +0000 +0000 +0000 +0000 +0000 +0000
< 22:54:38.565 8AF#8000#00: C0RXid0940
22:54:38.586 8AF#8000#00: C0RXid0940er00/00rx+05610
< 22:54:38.591 8AF#8000#00: C0ASid0941at0&tm1&xp05610&yp3120 3030 2940 2850 2760 2670 2580 2490th2450te2450lp1450&ch000&zl1330&zx1320&ip0000&it0&fp0000&av06242&as5000&ta000&ba0000&oa000&lm0&ll1&lv1&ld00&de0020&wt00&mv00000&mc00&mp000&ms3500&gi000&gj0gk0zu0113&zr09285&mh0000&zo000&po0000&lk0&ik0000&sd0500&se0500&sz0300&io0000&il00000&in0000&
22:54:45.009 8AF#8000#00: C0ASid0941er00/00
< 22:54:45.067 8AF#8000#00: C0RLid0942
22:54:45.115 8AF#8000#00: C0RLid0942er00/00lh+0000 +0000 +0000 +0000 +0000 +0000 +0000 +0000
< 22:54:45.704 8AF#8000#00: C0RXid0943
22:54:45.725 8AF#8000#00: C0RXid0943er00/00rx+05610
< 22:54:45.729 8AF#8000#00: C0DSid0944dm3&tm1&xp05610&yp3120 3030 2940 2850 2760 2670 2580 2490zx1320&lp1450&zl1330&ip0000&it0&fp0000&th2450te2450dv06242&ds5000&ss2500&rv000&ta000&ba0000&lm0&zo000&ll1&lv1&de0020&mv00000&mc00&mp000&ms3500&wt00&gi000&gj0gk0zu0113&dj00zr09285&mh0000&po0000&
22:54:50.437 8AF#8000#00: C0DSid0944er00/00
< 22:54:50.510 8AF#8000#00: C0RLid0945
22:54:50.558 8AF#8000#00: C0RLid0945er00/00lh+0000 +0000 +0000 +0000 +0000 +0000 +0000 +0000
< 22:54:52.662 8AF#8000#00: C0RXid0946
22:54:52.684 8AF#8000#00: C0RXid0946er00/00rx+05610
< 22:54:52.688 8AF#8000#00: C0TRid0947xp04509&yp2418 2328 2238 2148 2058 1968 1878 1788tp1414tz1314th2450te2450tm1&ti0
22:55:00.680 8AF#8000#00: C0TRid0947er00/00kz310 330 280 300 310 310 360 280vz314 334 284 303 314 314 364 284
< 22:55:00.691 8AF#8000#00: C0RTid0948
22:55:00.736 8AF#8000#00: C0RTid0948er00/00rt0 0 0 0 0 0 0 0
< 22:55:02.802 8AF#8000#00: C0RXid0949
22:55:02.825 8AF#8000#00: C0RXid0949er00/00rx+04509
< 22:55:02.828 8AF#8000#00: C0TPid0950xp04599&yp2418 2328 2238 2148 2058 1968 1878 1788tm1&tt04tp2264tz2164th2450td1
22:55:09.238 8AF#8000#00: C0TPid0950er00/00sx466 466 466 466 466 466 466 466sg453 451 452 447 451 456 466 471
< 22:55:09.240 8AF#8000#00: C0RTid0951
22:55:09.284 8AF#8000#00: C0RTid0951er00/00rt1 1 1 1 1 1 1 1
< 22:55:09.379 8AF#8000#00: C0RTid0952
22:55:09.421 8AF#8000#00: C0RTid0952er00/00rt1 1 1 1 1 1 1 1
< 22:55:09.879 8AF#8000#00: C0RXid0953
22:55:09.901 8AF#8000#00: C0RXid0953er00/00rx+04599
< 22:55:09.905 8AF#8000#00: C0ASid0954at0&tm1&xp01900&yp2420 2330 2240 2150 2060 1970 1880 1790th2450te2450lp2271&ch000&zl1871&zx1871&ip0000&it0&fp0000&av00067&as5000&ta000&ba0000&oa000&lm0&ll1&lv1&ld00&de0020&wt00&mv00000&mc00&mp000&ms3500&gi000&gj0gk0zu0032&zr06180&mh0000&zo000&po0000&lk0&ik0000&sd0500&se0500&sz0300&io0000&il00000&in0000&
22:55:14.228 8AF#8000#00: C0ASid0954er00/00
< 22:55:14.300 8AF#8000#00: C0RLid0955
22:55:14.348 8AF#8000#00: C0RLid0955er00/00lh+0000 +0000 +0000 +0000 +0000 +0000 +0000 +0000
< 22:55:17.923 8AF#8000#00: C0RXid0956
22:55:17.945 8AF#8000#00: C0RXid0956er00/00rx+01900
< 22:55:17.949 8AF#8000#00: C0DSid0957dm3&tm1&xp06625&yp2420 2330 2240 2150 2060 1970 1880 1790zx1871&lp2001&zl1891&ip0000&it0&fp0000&th2450te2450dv00067&ds5000&ss2500&rv000&ta000&ba0000&lm0&zo000&ll1&lv1&de0020&mv00000&mc00&mp000&ms3500&wt00&gi000&gj0gk0zu0113&dj00zr09285&mh0000&po0000&
22:55:22.092 8AF#8000#00: C0DSid0957er00/00
< 22:55:22.163 8AF#8000#00: C0RLid0958
22:55:22.211 8AF#8000#00: C0RLid0958er00/00lh+0000 +0000 +0000 +0000 +0000 +0000 +0000 +0000
< 22:55:23.032 8AF#8000#00: C0RXid0959
22:55:23.054 8AF#8000#00: C0RXid0959er00/00rx+06625
< 22:55:23.058 8AF#8000#00: C0ASid0960at0&tm1&xp06625&yp2420 2330 2240 2150 2060 1970 1880 1790th2450te2450lp2001&ch000&zl1921&zx1871&ip0000&it0&fp0000&av00062&as2500&ta050&ba0000&oa050&lm0&ll1&lv1&ld00&de0020&wt10&mv00000&mc00&mp000&ms3500&gi000&gj0gk0zu0113&zr09285&mh0000&zo000&po0000&lk0&ik0000&sd0500&se0500&sz0300&io0000&il00000&in0000&
22:55:27.274 8AF#8000#00: C0ASid0960er00/00
< 22:55:27.348 8AF#8000#00: C0RLid0961
22:55:27.393 8AF#8000#00: C0RLid0961er00/00lh+0000 +0000 +0000 +0000 +0000 +0000 +0000 +0000
< 22:55:28.091 8AF#8000#00: C0RXid0962
22:55:28.114 8AF#8000#00: C0RXid0962er00/00rx+06625
< 22:55:28.118 8AF#8000#00: C0DSid0963dm3&tm1&xp05610&yp2100 2010 1920 1830 1740 1650 1560 1470zx2050&lp2180&zl2100&ip0000&it0&fp0000&th2450te2450dv00066&ds5000&ss2500&rv000&ta000&ba0000&lm0&zo000&ll1&lv1&de0020&mv00000&mc00&mp000&ms3500&wt00&gi000&gj0gk0zu0113&dj00zr09285&mh0000&po0000&
22:55:31.467 8AF#8000#00: C0DSid0963er00/00
< 22:55:31.544 8AF#8000#00: C0RLid0964
22:55:31.590 8AF#8000#00: C0RLid0964er00/00lh+0000 +0000 +0000 +0000 +0000 +0000 +0000 +0000
< 22:55:32.159 8AF#8000#00: C0RXid0965
22:55:32.181 8AF#8000#00: C0RXid0965er00/00rx+05610
< 22:55:32.184 8AF#8000#00: C0ASid0966at0&tm1&xp05610&yp3120 3030 2940 2850 2760 2670 2580 2490th2450te2450lp1450&ch000&zl1330&zx1320&ip0000&it0&fp0000&av06242&as5000&ta000&ba0000&oa000&lm0&ll1&lv1&ld00&de0020&wt00&mv00000&mc00&mp000&ms3500&gi000&gj0gk0zu0113&zr09285&mh0000&zo000&po0000&lk0&ik0000&sd0500&se0500&sz0300&io0000&il00000&in0000&
22:55:38.605 8AF#8000#00: C0ASid0966er00/00
< 22:55:38.684 8AF#8000#00: C0RLid0967
22:55:38.731 8AF#8000#00: C0RLid0967er00/00lh+0000 +0000 +0000 +0000 +0000 +0000 +0000 +0000
< 22:55:39.203 8AF#8000#00: C0RXid0968
22:55:39.226 8AF#8000#00: C0RXid0968er00/00rx+05610
< 22:55:39.230 8AF#8000#00: C0DSid0969dm3&tm1&xp05610&yp3120 3030 2940 2850 2760 2670 2580 2490zx1320&lp1450&zl1330&ip0000&it0&fp0000&th2450te2450dv06242&ds5000&ss2500&rv000&ta000&ba0000&lm0&zo000&ll1&lv1&de0020&mv00000&mc00&mp000&ms3500&wt00&gi000&gj0gk0zu0113&dj00zr09285&mh0000&po0000&
22:55:43.929 8AF#8000#00: C0DSid0969er00/00
< 22:55:44.005 8AF#8000#00: C0RLid0970
22:55:44.051 8AF#8000#00: C0RLid0970er00/00lh+0000 +0000 +0000 +0000 +0000 +0000 +0000 +0000
< 22:55:48.190 8AF#8000#00: C0RXid0971
22:55:48.211 8AF#8000#00: C0RXid0971er00/00rx+05610
< 22:55:48.215 8AF#8000#00: C0TRid0972xp04599&yp2418 2328 2238 2148 2058 1968 1878 1788tp1414tz1314th2450te2450tm1&ti0
22:55:56.218 8AF#8000#00: C0TRid0972er00/00kz310 330 280 300 310 310 360 280vz314 334 284 305 314 314 364 284
< 22:55:56.227 8AF#8000#00: C0RTid0973
22:55:56.271 8AF#8000#00: C0RTid0973er00/00rt0 0 0 0 0 0 0 0
< 22:55:58.334 8AF#8000#00: C0RXid0974
22:55:58.356 8AF#8000#00: C0RXid0974er00/00rx+04599
< 22:55:58.359 8AF#8000#00: C0TPid0975xp04689&yp2418 2328 2238 2148 2058 1968 1878 1788tm1&tt04tp2264tz2164th2450td1
22:56:00.232 8AF#8000#00: P6 er00 sm Z Drive Error 62; 1. Try; Actual Position = 27523; Target Position = 21104;
22:56:00.758 8AF#8000#00: P6 er00 sm Z Drive Error 62; 2. Try; Actual Position = 27443; Target Position = 21104;
22:56:01.099 8AF#8000#00: P5 er00 sm Tip Pick Up Error 78; 1. Try; Tip Target Z Position = 466; Tip Z Position = 1257; Tip Presence Sensor = 0
22:56:01.271 8AF#8000#00: P6 er00 sm Z Drive Error 62; 3. Try; Actual Position = 27411; Target Position = 21104;
22:56:01.496 8AF#8000#00: P4 er00 sm Tip Pick Up Error 78; 1. Try; Tip Target Z Position = 466; Tip Z Position = 784; Tip Presence Sensor = 0
22:56:01.573 8AF#8000#00: P5 er00 sm Tip Pick Up Error 78; 2. Try; Tip Target Z Position = 466; Tip Z Position = 1249; Tip Presence Sensor = 0
22:56:02.101 8AF#8000#00: P5 er00 sm Tip Pick Up Error 78; 3. Try; Tip Target Z Position = 466; Tip Z Position = 1246; Tip Presence Sensor = 0
22:56:02.624 8AF#8000#00: P5 er00 sm Tip Pick Up Error 78; 4. Try; Tip Target Z Position = 466; Tip Z Position = 1241; Tip Presence Sensor = 0
Yes, from your video, certainly looks like static to me. We’ve seen this happen with bravo tips, lynx tips; first time I’ve seen with Hamilton tips, but we use the black ones. Exhibits the same kind of wobbliness though. Ionizer and temp/humidity monitoring would be good ideas.
I love platform agnostic software, platform agnostic hardware, platform agnostic assays but hate platform agnostic issues. :rofl:
This issue was still reported at 60% humidity by the way so static cling seems less likely
Given the way it was floating there I still think it’s static related.
This could point to some of the other issues I mentioned above.
If there are isolated potential planes in the system, this could certainly contribute to the effect.
Are you using a BVS or CVS? Had any spills in the rear near the carrier stops?
I’ll try out the other suggestions. We have a service tech coming in on Tuesday. What’s BVS/ CVS?
On deck vacuum systems. Notorious for leaking fluids onto the decks which can contribute to grounding issues.
I only ask because they tend to require additional cleanup during PMs and maintenance.
You’d know it if you had one I think.
