SQL transaction error
Hi @DrDode,
Yes, this is a Vector Database error. There are several posts that might assist with this issue:
The error could go away by simply restarting the PC on a regular basis, which clears temporary memory. The LogFiles folder and/or the SQL sSrver itself may need to be cleaned up to create additional space. Other processes running on the PC or over the network could also interrupt communication leading to errors like this.
If you check the Windows Event Viewer logs around the time of the error, you may also be able to determine a more exact cause.
